Gigabyte GV-R9700pro Review (2)
Overclocker 2 Sep 2002
We conduct the a number of tests on the setup with the following configuration :
Test System:
  • Intel Pentium 4 2.8
  • Shuttle AS45GTR SiS 648 mainboard running DDR333 Async mode CAS 2, 2-2-5
  • Maxtor D740X-6L ATA133 7200RPM
  • AOPEN 40X CDROM
  • Gigabyte GV-R9700pro ATi drivers 6.13.1.6143
  • Corsair 512MB XMS3200 DDR400 module
Madonion 3DMark2001SE Build 330 and Overclocking
Benchmarking and overclocking the GV-R97000Pro is quite exciting. By default 325/310 (core/memory), we used the latest edition of the software tool Powerstrip 3.20 build 304 to tune up the Core and later the memory. When we run at 378/337.25, we are able to achieve a score of 15272 3DMarks.
If we compare both the Chaintech Ti4600 default and R9700Pro default, we can see that the R9700Pro is definitely leading the GF4 Ti4600 by around a 1400 points or 10.8%.
