  SiS 746FX Reference Board Review (1)
Overclocker 8 Jan 2002
SiS746FX
We saw the SiS 746's performance some time ago on the ECS K7S7AG GameUnion board, today we bring you our first hand information on the long awaited SiS 746FX chipset which promises better performance at a good cost/performance ratio. unlike its predecessor the SIS 735 and SiS 745, it uses a north south bridge architecture. The SiS746FX features an AGP 8X bridge, and a DDR-400 Memory controller, supporting AMD Athlon S2K FSB up to 333 MHz. The SiS746FX, via the second-generation 1 GB/s Multi-threaded I/O link, interconnects the SiS963L Media I/O that integrates one EHCI compliant USB2.0 host controller, 2 OHCI compliant USB1.1 host controllers, the ATA-133 dual IDE controller, AC 97 V2.2 compliant audio controller, and the Ethernet MAC controller with standard MII interfaced as shown in the diagram, the SiS746FX/ SiS963L System Block
Diagram.
Features Benefits
CPU supported AMD Athlon XP FSB 333 MHz.
DDR400 support Support Maximum Memory Bandwidth 3.2G/B.
MuTIOL 1GŪ technology Proprietary Interconnect between SiS746FX and SiS963L.SiS MuTIOL 1GŪ deliver 1GB/s bandwidth.
8X AGP upgrade flexibility Make system performance upgrade and user's facilitation.Support Maximum AGP interface bandwidth 2.1GB/s.Backwards compatible with AGP 4X.
ATA133 enhancement Fastest storage support. Increasing data/file transfer rate.
AC97 Controller Hollywood 3D stereo enriches audio surrounding with up to six channels.
Integrated Communication Controller for LAN or HPNA use MII interface used for 10/100Mbps LAN or 1/10Mbps HomePNA function. Reaching cost-effective solution and design elasticity.
Integrated USB2.0 Controllers One controller for six ports, achieving real legacy free systems.
Copyright 1998-2004
http://www.ocworkbench.com
