Chaintech VNF3-250 NF3-250 Mainboard Preview (1)
Gortok 8 May 2004
Chaintech has long been known for building reliable enthusiast motherboards and video cards. Though I've never owned one, I've read many reviews and many forums and never heard anyone say anything bad about their products. This is one of the reasons I decided to try them out on their newest Socket 754 board. The very latest is their "value" version of NVidia's latest single chip solution, the NForce3-250. This is not the NF3-250Gb. The Gb version incorporates a Gigabit Lan and hardware firewall.
Chaintech  has, in the past, packed a nice bunch of "extras" in their MB boxes. These range anywhere from  color coordinated rounded cables, card readers, SATA power adapters, etc, to software packages worthy of honorable mention...Today, we look at a new version of accessories also.
This board has also been "chained" to never-ending stress testing of Distributed Folding for Team OCW. Some of the photos taken will while the machine is being used....FOLD ON!
The Package
The contents: The motherboard, of course, Audio riser card (CNR slot), manual, 2 SATA cables, dual SATA power adapter-connector cord, 1x80-pin dual connector IDE cable, 1x FDD cable, 2xCDs for drivers and utilities and an IO sheild plate.
Form Factor
  • ATX Form Factor 305mm x 220mm
CPU
  • Supports the new generation of AMD Socket754 Athlon 64 CPU
  • Processor interface via 6.4GB/s Hyper Transport bus
Chipset
  • NVIDIA nForce3 250
Main Memory
  • Three 184-pin DDR DIMMs up to 2GB
  • Supports DDR266/333/400 modules
Expansion Slots
  • One AGP slot for both 4X/8X AGP
  • Five 32-Bit PCI slots (v2.2 compatible)
  • One CMR(Chaintech Mulmedia Riser) for Chaintech Multimedia Card (CMC5.1)
Audio Subsystem
  • With external high quality 5.1-Channel AC'97 Codec
    Complete software driver supports for Windows OS
    Support S/PDIF out
Video Subsystem
  • 4X/8X AGP
UltraDMA IDE Ports
  • Build-in nForce3 250 supports 2 ATA66/100/133 IDE ports
FDD
  • One FDD connector supports up to 2.88MB
Embedded USB Controller
  • Build-in nForce3 250 supports total 6 USB2.0 ports with High-Speed Device@480 Mb/s Transfer Rate
Embedded system monitoring
  • 2 temperature sensing for CPU and system
  • 3 Fan speed monitoring (CPU, system and Chipset)
Boot-Block Flash ROM
  • Award system BIOS supports PnP, APM, DMI, ACPI, & Multi-device booting features
Software
  • Driver CD
  • Value Pack 2004
Other Feature
Rear panel I/O ports
  • One PS2 Mouse and Keyboard port
  • Four USB ports and one RJ45 connector
  • Two 9-pin D-Sub male Serial ports
  • One 25-pin D-Sub female Parallel port
  • Audio I/O jacks (Line-in, Line-out and Mic-in)
On-board Ethernet
  • On-board LAN controller RTL8100C supports 10/100Mb Fast Ethernet
On-board SATA RAID Controller
  • Build-in nForce3 250 supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0/1 solution
On-board VIA VT6306 IEEE1394 Host Controller
  • On-board VIA VT6306 IEEE1394 Host Controller supports 3 IEEE1394 ports with Serial bus data rates of 100, 200 and 400Mbps.
  • IEEE P1394a compliant and IEEE Std. 1394-1995
On board connector for external device
  • Four 3x1 pin fan connectors
  • 5x2 pin USB connector for additional 2 USB ports
  • 3x1 pin wake on LAN connector with housing
  • 3x1 pin wake on Modem connector with housing
  • Two 4x1 pin CD-in connectors with housing on CMC5.1
  • 4x1 pin Aux-in connector with housing on CMC5.1
  • 9x2 pin front panel connector
  • 5x2 pin front side audio connector
  • 20 pin ATX Power connector
  • 4 pin ATX 12V Power connector
Copyright 1998-2005
http://www.ocworkbench.com
