Gigabyte 3D
Cooler-ULTRA PCU31-SD Review (2)
Bluetooth 28 Apr 2004
The heatink is viewed from various angles.
Specs
| Heatsink Dimension |
83 x 83 x 90mm |
| Rated Voltage |
12V |
| Rated Current |
0.15A (0.5A Max.) |
| Fan Speed |
2500±10% rpm (Default)
1900±10% rpm (With fan speed control
cable)
| Noise |
23.7dBA at 2500rpm
18.5dBA at 1900rpm
| Bearing Type |
Ball bearing |
| Life Expectancy |
50000Hr |
| Total Weight |
760 g |
| Application |
Intel® Pentium® 4
478 3.4GHz
AMD Athlon™ XP 3400+
AMD Athlon™ 64 3400+
| Package Contents: |
GH-PCU31-SD Cooler
Heat sink paste Injector (ShinEtsu
X-3-7762)
Intel® Pentium® 4
Clips
AMD Athlon™ XP Clip
AMD Athlon™ 64 Clip
Fan Speed Control Cable
