ECS KA1-MVP K8 CrossFire Mainboard Preview 2/3
Bluetooth 6 Oct 2005
Pricing of X850XT cards
The mainboard
Socket 939 for AMD K8 Athlon 64/ Athlon 64 FX
processor.
High-performance HyperTransport CPU Interface
Support transfer rate of 2000/1600/1200/800/400 mega-transfers per second.
CHIPSET
ATI RD480 & ATI SB450
North Bridge: ATI RD480
South Bridge: ATI SB450
MEMORY
Dual-channel DDR memory architecture
4 x 184-pin DDR DIMM socket support up to 4 GB
Support DDR400/333 2.5V DDR SDRAM
EXPANSION SLOT
2x PCI Express x16 slot
2x PCI Express x1 slot
2x PCI slots
STORAGE
Support by SB450
-4 x Ultra DMA133/100/66 device
-4 x Serial ATA devices
RAID0, RAID1 configuration
Support by SiI3132
-2 x SATAII devices
AUDIO
Realtek ALC880 8-channel audio CODEC
IEEE 1394a (optional)
VIA VT6307 support 2 x IEEE1394a ports
LAN (Dual-LAN)
Marvell 88E8053 Gigabit LAN controller
Realtek RTL8100C 10/100 Mbps Fast Ethernet Controller
REAR PANEL I/O
1 x PS/2 keyboard & PS/2 mouse connectors
4 x USB ports
1 x VGA port
1 x RJ45 LAN connector
1 x Serial port (COM1)
1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS
1 x 24-pin ATX Power Supply Connector
1x 4-pin 12V Connector
1 x FDD connector supports two 360K~2.88MB FDDs
2 x IDE connectors
6 x Serial ATA connectors
1 x IrDA for SIR header
2 x 1394a header (optional)
2 x USB 2.0 header support additional 4 USB ports
1 x SPDIF out header
1 x Front panel switch/LED header
1 x Front panel audio header
CD in/AUX-in header
CPUFAN/NBFAN/SYSFAN connectors
1x 26-pin Print header
SYSTEM BIOS
Award BIOS with 4Mb or 8Mb Flash ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Supports ACPI revision 1.0 specification
FORM FACTOR
ATX Size, 305mm*244mm
