Gigabyte Bluetooth USB Dongle GN-BT02 1/2 Bluetooth 14 Feb 2004
BT Dongle by Gigabyte GN-BT02
If you have been thinking about hooking up
your PDA and your mobile phone using Bluetooth technology. Gigabyte has one
readily available. Weighing just less than 30g and a quarter of the size of the
Ez-link card. This is definitely one of the smaller units you can find in the
market today.
The GIGABYTE USB Bluetooth Adapter adds
Bluetooth capability to your USB-equipped computer. Connect any
Bluetooth-enabled device to your Desktop PC or Notebook and reduce or eliminate
existing cable clutter.
This unit is
based on the IVT Corp. The bundle comes with the drivers disc that includes
BlueSoleil which is basically the software that controls the device on
connections with other BT peripherals.
Supports multiple
Bluetooth profiles
Allows users to access Internet, send Faxes,
play games, transfer files, print documents from a Bluetooth enabled printer
Allows users to listen to high-quality
stereo music
Connects to Bluetooth enabled keyboards,
mice or joysticks
Works with a Bluetooth headset via audio
in/out on a PC or mobile phone
Allows user the ability to create a
Bluetooth Personal Area Network with other compatible Bluetooth devices
Exchanges or synchronizes Personal
Information Manager data
