ASRock 939Dual-VSTA ULi M1695 Review Intro 1/6
Bluetooth 18 Aug 2005
939Dual-VSTA
Package
Last year, we reviewed the ASRock 939Dual-SATA2. There were lots of discussions of this outstanding board that provided a good price point for Socket 939 users. ASRock 939Dual-VSTA is supposedly the newer edition of this board which makes this board VISTA Hardware Ready.
If you remember, ULi M1695 paired with its southbridge M1567 is the first Athlon 64 / FX / X2 supporting chipsets allowing you to tap the power of your old high end AGP 8x graphics card at native speeds. On top of that, it also supports a PCIe x 16 slots for graphics cards. With its T.G.I technology, you can add on another PCI graphics card and do a 6 monitor screen surround video output. The chipset was quite overclockable and performed as good as NF4 Ultra boards and SLI.
Most of the functions like Jmicron SATA II controller to boost the HDD performance. Not only that it has a FUTURE_CPU_PORT for the AM2 CPU Board which we have reviewed before.
ASrock 939Dual-VSTA is Vista™ Premium Logo Hardware Ready full fledge ATX board based on the ULi M1695/M1567. It supports the Socket 939 AMD Athlon 64x2, 64, FX, Sempron processors with a FSB of 1GHz of HTT. It supports cool n quiet, 4 GB of Dual channel DDR 400. It has 1 AGP 8x, 1 PCIe x16 slot,1 PCIex1 slot and Future CPU Upgrade Slot. This board offers 2 IDE channels for connecting 4 IDE HDDs and 2 SATA ports for SerialATA 1.5Gb/s, RAID 0,1,JBOD. There is another SATA II 3.0Gb/s SATA connector for a third SATA HDD. Audio wise, 7.1 ch HD audio is supported using Cmedia codec. It has 4 ready to be used USB 2.0 ports with 4 more thru expansion cables. There is no GbE but it is equipped with  Fast Ethernet LAN.
The board also supports ASRock U-COP, Boot Failure Guard, CPU Multiplier Adj, CPU Vcore Voltage Adj, CPU Freq Stepless Control, AGP/PCIE Freq Control, DIMM Voltage Adj, CPU Quiet FAN.
Vccm (DRAM): Low (2.6v), Normal (2.7v), High (2.8v)
V(NB): Normal (2.0v), High (2.1v)
V(SB): Normal (2.0v), High (2.1v)
The package comes with  cables, CDROM and manual.
Specifications
CPU - Socket 939 for AMD Athlon™ 64FX / 64X2 / 64 Processors
- FSB 1000 MHz (2.0 GT/s)
- Supports Hyper-Transport Technology
Chipset - Northbridge: ULi® M1695
- Southbridge: ULi® M1567
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Memory - Dual Channel DDR memory technology
- 4 x DDR DIMM slots
- Supports DDR400/333/266
- Max. capacity: 4GB
Expansion Slot - 1 x Future CPU Port (Supports CPU upgrade from AMD Socket 939 CPU to Socket AM2 CPU through AM2CPU Board)
- 3 x PCI slots
- 1 x PCI Express x16 slot
- 1 x PCI Express x1 slot
- 1 x AGP 8X slot
Graphics - n/a
Audio  - C-Media CM6501 7.1 channel audio compliant with UAA architecture
LAN - Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Connector - 2 x Serial ATA 1.5 Gb/s connectors, support RAID (RAID 0, RAID 1, JBOD) and "Hot Plug" functions
- 1 x Serial ATAII 3.0 Gb/s connector by JMicron JMB 360 (PCIE x1 interface), supports NCQ, AHCI and "Hot Plug" functions
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 1 x USB 2.0 header (supports 2 USB 2.0 ports)
Rear Panel I/O  ASRock 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x RJ-45 Port
- Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
BIOS Feature - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 cables
Form Factor - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS - Microsoft® Windows® 2000 / XP / XP 64-bit / Vista™ compliant
Certifications - FCC, CE, WHQL
