ASRock AM2NF6G-VSTA AM2 board (NF6100-405) Review Intro 4/5
Bluetooth 3 Aug 2006
 Pricing from
various
vendors
BIOS I
AM2NF6G-VSTA comes with something new, it is known as AM2 Boost which claims to boost memory performance by up to 12.5%. Over at this screen, you can set the Overclock mode to PCI ASYNC so that PCIe can be fixed at 100 or you may want to o/c it up selectable to 200MHz. CPU Frequency can be adjusted from 200 ~ 400MHz. Cpu mutliplier options of up to 25x can be chosen.
CAS Latency, tras, trcp, trd, MA timing can be adjusted too (not shown in the diagram above)
Memory CLK can be adjusted to run in SYNC or ASync. 4 options are available as shown above.
Processor voltage can be set up to 1.40v on my 4000+ CPU NB link can be set to 800MHz or lower if you intend to o/c the board beyond the CPU freq of 233MHz so that Hypertransport is within 1GHz++.
