Introduction of ASUS P5E-VM HDMI Intel G35 Mainboard Review
Bluetooth 9 Dec 2007
Introduction
If you are looking for a new board that supports future 45nm and has full support for HDMI/HDCP HD playback to large screen LCD, ASUS P5E-VM HDMI will definitely fit the bill. Based on the G35 chipset which spots the X3500 integrated graphics, it is the first DX10 compliant integrated graphics chipset. With this new chipset, not only 3D performance is improved, the 2D video quality during playback of DVD and HD DVD is also greatly improved.
The Graphics Media Accelerator X3500 supports dual VGA output support: HDMI/DVI-D and RGB
It also supports RGB with max. resolution 2048 x 1536@75Hz, s HDMI with max. resolution 1920 x 1200@60Hz and  DVI with max. resolution 1920 x 1200@60Hz. A maximum shared memory of 384 MB. It also supports Microsoft® DirectX® 10, OpenGL® 2.0, Pixel Shader 4.0. Currently the driver does not support DX10 as yet. *The DirectX® 10 driver will be provided by the chipset vendor later.
This board supports the CPU LGA775 socket for Intel® Core™2 Quad / Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 Processors, compatible with Intel® 05B/05A/06 processors and support Intel® next generation 45nm Multi-Core CPU.
The board supports 4 x DIMM, max. 8GB, DDR2 800 / 667 MHz, non-ECC, un-buffered memory
Dual channel memory architecture. It has 1 x PCI-E x16, 2 x PCI-E x1 and 1 x PCI slot. The board also sports 6 SATA II 3.0Gb/s slots with support of RAID 0,1,5,10 (Intel matrix storage technology). The board also incorporates a Jmicron PATA/SATA controller, a LAN Atheros L1 PCI-E Gigabit LAN controller, Realtek ALC 883, 8-channel High-Definition Audio. There is also support for 1394 using IEEE 1394 VIA VT6308P controller supports 2 x IEEE 1394a ports (one at midboard; one at back panel).
Although P5E-VM HDMI is a mATX board, it does come with a full featured BIOS for overclockers. Some other unique ASUS Features supported include :
ASUS AI Lifestyle Features ASUS AI Lifestyle Features:
- ASUS Splendid
ASUS Quiet Thermal Solution:
- ASUS AI Gear 2
- ASUS AI Nap
- ASUS Fanless Design
- ASUS Q-Fan 2
ASUS Crystal Sound:
- ASUS Noise Filter
ASUS EZ DIY:
- ASUS Q-Connector
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
Special Features ASUS MyLogo 3
Overclocking Features Precision Tweaker 2:
- vDRAM: 33-step DRAM voltage control
- vChipset (N.B.): 24-step chipset voltage control
- vFSB: 16-step FSB voltage control
- vCPU PLL: 16-step CPU PLL voltage control
SFS (Stepless Frequency Selection)
- vCore: Adjustable CPU voltage at 0.0125V increment
- FSB tuning from 200MHz up to 800MHz at 1MHz increment
- Memory tuning from 533MHz up to 1333MHz
- PCI Express frequency tuning from 100MHz up to150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
P5E-VM HDMI Specifications
Enjoy Full HD 1080p Multimedia Home-Theater Entertainment
- Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® G35 chipset
- Onboard HDMI Connector
- Dual-channel DDR2 800/667/533 MHz
- Dual Display
- 12xUSB 2.0
- All High-quality Conductive Polymer Capacitors
