Gigabyte P35-DQ6 (Intel P35) mainboard review - BIOS Screen Shots
Bluetooth 5 May 2007
AMD 690G
BIOS 1
P35-DQ6 comes with Robust Graphics Booster too. You can set it to auto, fast or turbo to boost the 3D graphics performance
CPU Clk Ratio allows you to set the multiplier of your processor. ES should have multipliers unlocked for you to lower down as far as 6x.
CPU Host Frequency. This board allows a window of 100MHz- 600MHz.
PCIe Freq ranges from 100~150MHz
CIA2 allows you to overclock the system in various modes shown above. Cruise, Sports, Racing, Turbo and Full Throttle
