. Gigabyte P35C-DS3R DDR2/DDR3 (Intel P35) mainboard review - Sandra 2007
Bluetooth 16 May 2007
Benchmarks
Sandra 07
The boards are first measured to ensure accuracy of CLK. In CPUZ test, we see that the CLK of the Gigabyte GA-965P-DQ6 is at 266.7 while the ASRock 4CoreDual-VSTA is at 266.1MHz. The Gigabyte P35-DQ6 and the Gigabyte P35C-DS3R stays at the 266.7MHz mark.
In the tests to follow, the Gigabyte P35-DQ6 board is run with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533. The ECS PN2 SLI2+ runs at 266.7 which is just exactly at the same clk speed as the Gigabyte GA-965P-DQ6. ASUS on the other hand has its 0505 bios tuned to 267.3MHz, that is a big higher than the rest of the boards in comparison. Will it give it a better edge during the benchmarks.
The Gigabyte P35C-DS3R is run at DDR2-1066.
At DDR2-1066, we can see that the P35C-DS3R seems to be well tuned for better bandwidth. If we were to compare it with the P35-DQ6, we can notice the difference which amounts to almost 200 points. Would that translate to better results? Let's read on.
