Samsung UltraTouch S8300 8 mega pixel camera phone user Interface
OCWorkbench 22 Apr 2009
The main interface looks very similar to the Pixon M8800 and the Omnia. it has a sidebar that is where all the widgets are located. You can drag and drop the widgets to the desktop or scroll the list of widgets.
On the desktop itself are 4 main menus "Keypad, Phonebook, Menu". With a touch, it brings you to the submenus for more options. See video on next page for options available.
Below is a picture of the phone with the keyboard slide out. In fact, the phone can be used without the keypad. By default, you can use the touch screen to make calls thru the keypad or phone book button on screen. You can select to lock the touch screen from the options in the phone so that you won't accidentally make a call unless you slide out the keypad.
The Phone Pad
Discuss >>>
