| DRAM Timing
Selectable is set to Manual and Ram Timing adjusted to CAS 2, 5-2-2. We
also enabled Agreeisve memory Mode and Enabled CPU BUS PARK, FAST CS, CPC
function. |
CPU
Clock/Speed can be adjusted up to 350MHz FSB. Memory Frequency can be set
to run at a ratio of the CPU speed. e.g. 1:1, 5:4 etc. |
