EPoX 8KDA3+
nForce3-250Gb Socket 754 Mainboard (5)
Benchmarking We checked out Q3 running Demo001 at 1024x768x32 Hi-Quality. Tyan Radeon 9700Pro is used and is running in 8X mode with Catalyst 3.2 (7.84) drivers for all boards tested. The score is 376fps is on par with most of the VIA based boards. We also noticed that if we disabled on the board LAN, we can push towards a 378fps.
In Comanche 4 benchmarks, 67.82 is recorded. This is the top score we got from the EPoX 8KDA3+ on the Comanche 4 tests. The screen flybys and is amazingly fast. If you noticed, BIOSTAR iDEQ200p based on the NF3-150 also reached a similar speed in a separate test months ago.
