ASRrock
939Dual-VSTA ULi M1695 Review Benchmarks 2/8
Benchmarks The ASRock 939Dual-VSTA runs at the default CLK of 200.00 MHz. In the following benchmarks, we will compare feature the benchmarks of the board with a AGP card and a PCIe card. For AGP, a Powercolor X1600Pro 512M card is used. For PCIe solution, a ASUS EN7600GT is used. The results for all the tests are very similar to that of the ASRock 939Dual-SATA2 since they're both based on the same chipset.
With that in mind, we take a look at the memory benchmark scores using Sandra 2007.
