ASRock 939Dual-VSTA ULi M1695 Review Intro 6/6
Bluetooth 18 Aug 2005
ASRock 939Dual-VSTA
BIOS II
DRAM timing settings has lots of options for you to tweak. The more important ones are 1T/2T Memory Timing. CAS Latency (tcl), RAS to CAS (tRCD), Min RAS#active time (tRAS), Row Precharge time (tRP) and Row precharge time (tRP). MA timing is 1T/2T. My settings is based on Corsair TwinX CAS 2 module. which runs at CAS 2, 5-2-2 1T MA timing. There is a hardware monitoring setting in the BIOS known as CPU Quiet FAN. You can set the target temperature and FAN Speed such that you can reduce the noise level of your system.
CPU -NB Hypertransport Link can be set to 200MHz - 1000MHz DRAM Voltage can be adjusted to Auto, Low, Normal, High. Vccm (DRAM): Low (2.6v), Normal (2.7v), High (2.8v)
North Bridge voltage : V(NB): Normal (2.0v), High (2.1v) South bridge voltage : V(SB): Normal (2.0v), High (2.1v)
