ASRock 4Core1333-eSATA2 Intel P31 Mainboard Review Intro 4/4
Bluetooth 6 Sept 2007
ASRock ConRoe1333-DVI/H
BIOS Screen shot
CPU Host Frequency range is up to 90MHz to 500MHz. PCIe Frequency can be adjusted to from 87 to 114Mhz.
DRAM Frequency can be set to operate in DDRII667 or DDRII800. IIn our test, we ran it at DDR2-800.
DRAM adjustments available and options to turn on/off HD AUDIO, LAN, 1394
Voltage adjustments for VCCM, options available are auto, high, middle, low and lowest
NB Core Voltage can be set to high or low
Vtt voltage can be set to High or low.
