ASUS EN8800GTX AquaTank/HTDP/768M  Review  - 3Dmark05/3Dmark06 results
Bluetooth 20 Mar 2007
GF8800GTX
Benchmarks
3DMark05
In this test, we ran the card in default clk settings at of 630/1030. Apparently, this clk speed already indicates that it is overclocked. In the test, a X6800 is used with 2GB of DDR2-800. The result shows that the factory o/c card with cooling excels in results against the other cards including the original 8800GTX. An overclocked 8800GTX aircooled would only reach around 610/1050 and scored 16920. With the ASUS EN8800GTX AquaTank, it scored 17214. The default clk NVIDIA ref card scored 16685. That gives the ASUS EN8800GTX AquaTank a 3% lead in performance over the original aircooled card.
3DMark06
In 3DMark06, the score are very apparent too. The default stock speed sets the record of 8639.
  SM2 HDR/SM3 CPU Score Total
ASUS EN8800GTX AquaTank 630/1030 5247 5355 5237 11391
X6800 with ref 4832 4948 2579 10776
X6800 oc with ref 5096 5761 2568 11234
QX6700 with ref 4812 4935 4064 11830
X6800 with Gigabyte 4821 4902 2535 10682
X6800 with ECS N8800GTS-320MX 3702 3700 2511 8639
From the results, the difference between the reference NVIDIA card and the ASUS gives a difference of around 5%.
