ASUS EN8800GTX AquaTank/HTDP/ 768M
Review Introduction
of
Installation The PCIe graphics card is slotted into the PCIex16 slot. The two power connectors need to be connected to the PSU through the provided connectors. Both the AquaTank and the graphics card comes with a 4 pin connector which needs to be plugged to any available molex connector to power them. In our case, we used an ANTEC 480W to power the card and Aquatank. The window below the knob is to observe the coolant level. If it is low, refill it by unscrewing the knob to refill the coolant.
Below is a photo of how it looks like from the front.
From the side view, we can see that the ASUS AquaTank actually uses the ThermalTake Cooling solution "TideWater". T
