Sandra XII
Benchmarks of
ASUS P5E-VM HDMI Intel G35
Mainboard Review
Bluetooth 10 DEC 2007
Benchmarks
We
test out the system using Sandra XII benchmarks
with a X6800 on both boards. One thing to note is that the default FSB on both
boards are a bit different. ASUS P5E-VM HDMI is slightly oc at 267.3MHz while
ECS G33T-M2 based on G33 chipset runs at 266.0. Ram timings are set
to SPD which runs at DDR2-800 CAS 5-5-5-18, 2T.
Sandra XII tests
Here are the results. Both boards gives very identical
results. Looks like the differences should reveal when 3D graphics is tested.
Sandra XII |
ASUS P5E-VM HDMI |
ECS G33T-M2 |
Memory Bandwidth |
5352/5390 |
5355/5348 |
Arithmetic - Drystone ALU |
27342 |
27202 |
Arithmetic - Whetstone iSSE3 |
18889 |
18853 |
Multimedia - Int x8 iSSE3 |
161794 |
161788 |
Multimedia - Float x4 iSSE2 |
88110 |
87618 |
Disk - Drive Index |
47 |
47 |
Disk - Random Access |
8 |
8 |
