F.E.A.R benchmark
of
ASUS P5E-VM HDMI Intel G35 Mainboard Review
Benchmarks - F.E.A.R In the F.E.A.R Multiplayer DEMO benchmark, the results vary quite a lot, depending on how you place the setting. In the chart below, the first parameter means CPU is set to MAX and the second parameter is the graphics performance. It can be seen that this game is only playable when the graphics is set to Low or Min. Again, we see that the scores of both boards are largely identical, in fact in this test, the G33 seems to run a bit faster.
