You can disable auto AI overclocking by setting it to
manual mode. Once manual mode is enabled, you can see the various options
like Ratio control (ES), NB Strap, FSB frequency, PCIe frequency, DRAM
frequency, DRAM timing controls |
You can set the FSB Strap to North bridge to 200,266 or
333MHz. This option will be useful when you want to let the system think
that you are using a 1066fsb processor but in fact you are using a 800fsb
processor. |
