Foxconn 915A01-P-8EKRS 915P Socket T Review (2)
Bluetooth 20 Sep 2004
Benchmarks
Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that Foxconn runs it at exactly 200.00. That makes our tests simpler as some brands uses overclocking technology to boost scores.
We used a pair of the Samsung DDR2-533 set at CAS 3, 11-4-4 and we scored 4940/4912. It is surprising as the scores actually beat the 925A01 with a few points. Will this impact the actual performance. Could it be because there is a bit more latency on 925x because it supports ECC. We shall see.
Discuss in Foxconn sector
