ASRock AM2NF6G-VSTA AM2 board (NF6100-405) Review Intro 1/5
Bluetooth 3 Aug 2006
 Pricing from
various
vendors
ASRock AM2NF6G-VSTA
Yesterday, we posted news about the new single chipset NF6100-405, which is a two in one chipset integrating the former 6100 + 410 into a single chip. ASRock surprises me again with a board based on this low cost NVidia chipset that will probably raise a few eyebrows from other manufacturers.
This new mainboard uses a single chipset NF6100-405 that comes integrated with a DX9 video PS3.0 that can be configured up to 256MB of shared memory.
Just like the other AM2 boards reviewed before, this board supports dual channel DDRII-800/667/533 with 4 DIMM slots with a max capacity of 8GB. This mainboard also boost a new patented technology to boost memory performance up to 12.5%. With its untied PCIe/PCI clk, some overclocking can be done with this board.
The board also supports 2 SATA II 3.0Gb/s supporting RAID 0,1, JBOD, NCQ and hot plug functions. There is Fast ethernet, a 7.1 ch VISTA premium level HD Audio using the ALC888 audio codec. There is 1 PCIe x8 for external VGA card. The board is Windows® Vista™ Permium Logo Hardware Ready.
Specs
CPU - Socket AM2 for AMD Athlon™ 64FX / 64X2 / 64 and Sempron processors
- FSB 1000 MHz (2.0 GT/s)
- Supports Hyper-Transport Technology
Chipset - NVIDIA® NF-6100-405
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
Memory - Dual Channel DDRII memory technology
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 8GB
Expansion Slot - 2 x PCI slots
- 1 x PCI Express Graphics slot
- 1 x PCI Express x1 slot
- 1 x HDMR slot
Graphics - Integrated NVIDIA® GeForce6-class graphics DX9.0 VGA
- Pixel Shader 3.0
- Max. shared memory 256MB
Audio - Realtek ALC888 7.1 channel CODEC with High Definition Audio
LAN - Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Connector - 2 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, JBOD), NCQ, and "Hot Plug" functions
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x COM Port header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O HD 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA Port
- 1 x RJ-45 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
BIOS Feature - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 cables
- 1 x COM port bracket
- 1 x HDMR card (optional)
Form Factor - Micro ATX Form Factor: 9.6-in x 9.6-in, 24.4 cm x 24.4 cm
OS - Microsoft® Windows® 2000 / XP / XP 64-bit / Vista™ compliant
Certifications - FCC, CE, WHQL
