ASUS P5K3 Deluxe DDR3 (Intel P35) mainboard review - BIOS Screen Shots
Bluetooth 26 May 2007
ASUS P5K3 Deluxe
BIOS 1
DRAM Frequency allows you to run the RAM at ASYNC ratio to the CPU CLK. On this board, when FSB is set to 266MHz, the DRAM freq will just show up to DDR3-1066. FSB can be set from 200 ~ 800MHz. The higher you go, the more async ratio appears for your selection. In fact, DDR3-1333 is the somewhat the preferred choice when a 1333FSB CPU (to be available) is used.
CAS Latency options available : CAS 5 to CAS 10
CPU Voltage can be set up to 1.70v
CPU Voltage reference option
CPU PLL voltage adjustments
