ASUS P5K Deluxe (Intel P35) mainboard review - Introduction
Bluetooth 27 May 2007
ASUS P5K Deluxe
Introduction
ASUS P5K Deluxe is ASUStek's first DDR2 board based on the Intel P35 chipset. This board supports all series of Intel LGA775 processors ranging from Core 2 Extreme to Core 2 Quad, Core 2 Duo, Pentium Extreme, Pentium D and Pentium 4 processors. Based on the Intel P35/ICH9R pair, it supports Intel fast memory access technology and supports a sytsem bus of 1333/1066 and 800MHz.
The board consists of 4 DDR2 slots supporting up to 8GB of DDR2-1066/800/533/400 non-ECC unbuffered memory. The board supports CrossFire with the 2 PCIe x16 slot, one operating in 16x while the other in 4x mode.
The ICH9R spports 6 SATA II RAID 0,1. There is an addtional PATA and SATA controller based on Jmicron JMB363 and it supports SATA RAID 0,1, and JBOD. Other features on this board includes Dual GbE featuring AI NET2, ASUS WiFi_AP Solo for Wireless LAN connection or change it to a Access point mode. The audio on board uses the ADI AD1988b 8 ch hda codec with Coaxial optical S/PDIF out ports at the back of the panel. 1394a is also available on board powered by the Agere chipset.
If you notice the design, it looks very similar to Striker Extreme. The Pure copper heat pipe design lowers temperatures by up to 16 Deg Celsius buy directing the heat generated by chipsets to the back of the mainboard. In addition, the Stack Cool 2 effectively cools and temperatures of up to 20 deg celsius. The heatsink looks different from the P5K3 Deluxe.
