ASUS P7P55D Premium Intel P55 Mainboard BIOS Screen shots 2
Bluetooth 8 Sep 2009
BIOS 2
The screen shots are taken with board installed with a Core i5 750.
Voltage levels can be adjusted in the BIOS.
CPU voltage can be set in two modes. Offset or manual mode.
Offset mode range is from 0.00625v - 0.5v where as manual ranges from 0.85v - 2.10v
DRAM range 1.5 - 2.5v
CPU PLL voltage 1.8v - 2.1v
PCH voltage 1.05, 1.15v
This board supports up to 8 profiles. You can save your overclocked profiles into one of the 8 slots so that you can reuse it. You can also export it and share it with your friends.
ASUS EZ Flash 2 allows you to flash bios without entering the Windows . It can be done at BIOS level. Express Gate OS timer can be set
A screen shot of Express Gate running game, chat, browser etc.
