DiVX Encoding tests benchmark
of
ASRock H55M Pro Intel H55 ClarkDale Mainboard
Benchmarks - DIVX 7 encoder In this test, a full HD clip is put to the compression test to Divx Plus HD and Divx Mobile Format. In the chart below, the shorter the time to completion equates better performance. From the numbers shown below, we can see that the faster platform is the Intel H55. Among the 3 Intel H55 boards, the ASRock H55M Pro gives the fastest encoding result. The AMD 785G is almost on par but just split seconds slower than the rest.
