BIOS Screen shot 2 of ASRock H55M Pro  mainboard
Bluetooth 3 Jan 2010
BIOS 2
In Chipset settings, you can manually change the ram timings
CPU voltage can be adjusted, from 0.04375v to 1.60v
DRAM voltage 1.30 - 2.05v VTT can be set too from 1.11v to 1.55v
PCH voltage can be set from 1.05, 1.15 and 1.25v CPU PLL voltage range 1.01v to 2.18v
GFX voltage can be adjusted too by adding up to 300mV You can save 3 profiles for future use or reference.
