ASRock 939Dual-VSTA ULi M1695 Review Intro 5/6
Bluetooth 18 Aug 2005
ASRock 939Dual-VSTA
BIOS
Advanced Menu. Many settings are available for the tweakers. We can see Overclock mode, CPU Freq, PCIE Frequency, Multiplier, Voltage, Memory Clock, DRAM timings etc. Overclock mode can be set to CPU/PCIe Sync or CPU,PCIe ASync mode. This allows running the clks independently of the CPU Frequency. CPU Freq range is from 200~400MHz. PCIe Freq is from 75~200MHz.
Multiplier can be set from 4x to 25x CPU Voltage can be set up to 1.550v for FX-53. Different CPUs might have different maximum voltage
Memory Clock can be set to run in Sync DDR400 or ASync DDR266 or DDR333 mode In this page, you can set the parameters for AGP card. The AGP aperture size, data rate, fast write. AGP P2P Deep FIFO (for compatibility issue with certain AGP cards)
