ASRock ALiveXFire-eSATA2 ATi Xpress 1600 (RD480+SB600) Mainboard Review Intro 4/5
Bluetooth 1 Oct 2006
 Pricing from
various
vendors
BIOS I
ASYnc memory setting of ram running at DDR2-400,533,667 or 800. For o/c, it is better to run the RAM in SYNC with CPU CLK so that the RAM will not be reaching 400MHZ (DDR2-800) CAS Latency, tras, trcp, trd, MA timing can be adjusted too (not shown in the diagram above)
CAS Latency selection CAS 3, 4, 5 and 6
HT link Speed can be set from 1x-5x (200MHz - 1GHz) Llink width can be set to 8 or 16bits
NB Core voltage can be set to auto, ultra high, high, normal and low. NB+1.8voltage can be set to auto, High or Low to improve stability during OC.
