ASRock 4CoreDual-VSTA Review Benchmarks - Sandra 2007
Bluetooth 19 Nov 2006
Benchmarks
Sandra 07
The boards are first measured to ensure accuracy of CLK. In CPUZ test, we see that the CLK of the Gigabyte GA-965P-DQ6 is at 266.7 while the ASRock 4CoreDual-VSTA is at 266.1MHz.
In the tests to follow, the Gigabyte board is ran with 2GB of Corsair DDR2 running at CAS 5, 5-5-18 DDR2-800 mode while the ASRock 4CoreDual-VSTA will run in DDR mode with 1GB of Corsair memory at CAS 2, 2-2-5, 1T cmd and in DDR2 mode, it is run with the same pair of DDR2 modules (2GB) running at CAS 3, 3-3-8, 1T cmd DDR2-533.
As we can see from the chart below, running the DDR400 memory module gives us a lower memory score while running the DDR2 module at CAS 3, 3-3-8, 1T gives a better rating when run in CAS 5, DDR2-800 on the intel 965p chipset.
