Benchmark test of the Kingston HyperX KHX1100D3LLK2/2G DDR3-1066 (2x1GB) Review
Bluetooth 2 Jun 2007
AMD 690G boards
Benchmarks
The 2 pieces of Kingston memory module are mounted to the Gigabyte P35T-DQ6 for the tests. We did a test run of the modules at its rated speed, that is, setting it to SPD and let the system detect it to run at CAS 7-7-7-20, DDR3-1066 (default async ram multiplier is detected as 4x, CPU runs at 266MHz, DDR3 at 1066).
To prevent any skewed results due to overclocking, all speed enhancements in the BIOS are set to Disabled.
